Design forum
Door Leafs missing
Eric Milberger
I don't think they are missing but new styles are ignored
Opened a model that was correct on laptop
On desktop the leafs do not show
And if I change the leafs - no change - just a flat panel or lo leaf - can't tell
Eric Milberger, Architect | Master Planner
Archicad 25
AecoSim
Microstation
Windows 10 64bit
Remote - i7-8550U CPU @ 1.80GHz, 2001 Mhz, 4 Core
Office - Processor i7-8700K CPU @ 3.70GHz, 3696 Mhz, 6 Core
1 REPLY 1
Check your Model View Options Settings.
The "3D and Section/Elevation" setting for Doors is probably not set to "Full", which is the reason why you see a simplified Door Leaf instead of a fully generated one.
Laszlo Nagy, Lead Moderator, Community Admin
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Didn't find the answer? Start a new discussion
