Project data & BIM
Edit Selection Set character cap
martinij
A little heads up to everyone who works with information management in models:
If you are writing long strings in to objects be aware that the maximum length of the string depends on wich dialog you use! If you go into the "Settings Dialog" you can write long strings to a property value. But if you use the "Edit Selecton Set" dialog you are caped to 63 characters!
So lets say you whant to paste a long URL into several objects properties you must eather use "Setings Dialog" or  make a schedule. If you use the "Edit Selection Set" dialog your long URL will be cliped and you will not get a warning.
Martin Isak Jansen
(I'm the one everyone at my company asks the tech questions)
www.artec.no
0 REPLIES 0
