Don't forget you can create composite walls that can have a skin for insulation.
Or if you need a wall profile that is not rectangular, you can create complex profiles.
These complex profiles can even have 'modifiers' now, so you can stretch individual skins - not just changing the height or width of the entire wall.
These complex profiles with modifiers is a bit like having a wall object, but because it is a wall it will interact with other walls, slabs, beams, etc.
