2021-05-14 08:55 AM - last edited on 2023-05-09 04:16 PM by Rubia Torres
2021-05-14 10:05 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2021-05-14 10:07 AM
2021-05-14 10:33 AM
Lingwisyer wrote:
Regarding your walls, are they multistory?
For the rest, other than the intended paste, duplicating in what way? Can you still see the relevant objects when you change stories?
Ling.
Given username, possible spam?
2021-05-14 10:39 AM
Barry wrote:
Are the original elements duplicates in the first place?
So you are actually copying and pasting multiple copies of the same elements?
Or are you sure there is only one of each original element/
2021-05-14 11:05 AM
2021-05-14 11:22 AM
Barry wrote:This isn’t the problem
If you place one object, then copy it and get duplicate copies, then there is something strange going on.
Barry wrote:If you mean having the same object duplicate in the same spot then no
I was wondering if you original object is already duplicated, so then you are copying and pasting duplicates rather than just one object.
2021-05-14 12:26 PM
2021-05-15 10:29 AM
For example, if I copy a shower from level 2 to level 3 it works and the shower’s home story will be level 3 but it may make a another copy of it and paste it in the same spot and on level 3 as well
Sammy1495 wrote:
Ps. how do I unmarked this topic as not solved. First time here
2021-05-15 04:24 PM
