2020-11-2504:09 AM - last edited on 2023-05-2504:51 PM by Rubia Torres
I'm having an issue with Solid Element Operations intersecting a mesh with slab for instance from two modular files, it wouldn't operate, let me see attached.
I tried unlocking no use.
I think you will find it is because you can not use a hotlink module as a target or operator in a SEO.
One of the forum moderators. Versions 6.5 to 27 Dell XPS- i7-6700 @ 3.4Ghz, 16GB ram, GeForce GTX 960 (2GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
Thanks you Barry,
you right because I'm using the mesh and slab both separate module file. but I tried one as a module and the other as PLN file and it works.
It would have been great if works with both files.
