Solid Element Operations with Modules
I'm having an issue with Solid Element Operations intersecting a mesh with slab for instance from two modular files, it wouldn't operate, let me see attached.
I tried unlocking no use.
could any one please help!
I think you will find it is because you can not use a hotlink module as a target or operator in a SEO.
Thanks you Barry,
you right because I'm using the mesh and slab both separate module file. but I tried one as a module and the other as PLN file and it works.
It would have been great if works with both files.
thanks for you suggestions
regards
Atheer
