2022-03-28 10:10 PM
Hi! I need to build stairs like in the attached screenshot. In this case I didn't manage to get the first 2 steps, which (not knowing how else to do it) in the screenshot are 2 different slabs shaped as if they were the first 2 steps of the stairs.
I would like to avoid usign the slab tool and to do it properly using only the stairs tool.
Can a you help me on that?
2022-03-28 11:33 PM
2022-03-29 01:34 PM
Thanks for your reply Martin. The problem is that my stairs are only structure (there is no finishing) and with the solution you propose, I can only modify the width of the steps. I cannot change the depth of the tread as in the previously attached image.
Subject | Likes |
6 | |
4 | |
3 | |
3 | |
3 |
