2023-02-20
04:19 PM
2023-02-24
02:26 PM
Daniel Kassai
I'm building a parametric component for a modular battery storage unit. Everything works in terms of basic geometry creation, but I want to finish the component with some additional details - recessed handles and grooves.
This is what the 'dumb' component looks like:
This is the parametric one:
I need to undertake a subtraction to create the grooves and handles. I've created groups, and looked up the SUBGROUP syntax, but I'm getting an error.
This is my script:
"top":
GROUP "topsection"
ADDZ (footheight*2) + baseheight + modoffset +((modoffset + modheight)* modcopies)
material mat2
!curved corner 1
ADDX footheight !footheight is same dimension as corner radius
ADDY footheight
CYLIND topheight, footheight
del 2
!curved corner 2
ADDX A-footheight
ADDY footheight
del 2
!curved corner 3
ADDX footheight
ADDY B-footheight
del 2
!curved corner 4
ADDX A-footheight
ADDY B-footheight
del 2
SLAB 4, topheight,
footheight, 0, 0,
A-footheight,0, 0,
A-footheight,B, 0,
footheight, B, 0
SLAB 4, topheight,
0, footheight, 0,
A, footheight, 0,
A, B-footheight, 0,
0, B-footheight, 0
ENDGROUP
GROUP "topgrooves"
!groove1
material mat3
ADDX footheight
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
GrooveWidth, GrooveDepth, 0,
0, GrooveDepth, 0
Del 1
!groove2
material mat3
ADDX A - GrooveWidth - footheight
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 1
!groove3
material mat3
ADDY B - GrooveDepth
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 2
!groove4
material mat2
ADDX footheight
ADDY B- GrooveDepth
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 2
ENDGROUP
topcomplete = SUBGROUP (topsection, topgrooves)
del top
RETURN
I've checked the syntax, but when I run the Check Script function, I get this error:
Group name or group type expression required at line 249 in the 3D script of file BYD Battery Box LVS.gsm.
I'm not sure what I'm doing wrong - any ideas?
Solved! Go to Solution.
2023-02-20 06:52 PM
There are actually two types of groups.
The result of the latter will be stored inside a variable – kind of like a function in other languages.
Funfact: VARTYPE will show type 2 for this variable (means string!), but you can not actually do string operations with this. Instead this works like a pointer to the resulting geometry stored in memory.
So check your SUBGROUP command: You use variables in error here, instead the names would need to be wrapped in quotes.
Happy coding!
2023-02-20 07:04 PM - edited 2023-02-20 07:09 PM
Thanks, I've fixed the group definitions, and amended the SUBGROUP syntax, but it's not working.
There are no errors, and the geometry is displaying correctly - except the geometry subtraction.
This is the script:
"top":
!ADDZ (footheight*2) + baseheight +((modoffset + modheight)* modcopies)
GROUP "topsection"
material mat2
!curved corner 1
ADDY footheight
del 2
!curved corner 2
ADDX A-footheight
ADDY footheight
del 2
!curved corner 3
ADDX footheight
ADDY B-footheight
del 2
!curved corner 4
ADDX A-footheight
ADDY B-footheight
del 2
SLAB 4, topheight,
footheight, 0, 0,
A-footheight,0, 0,
A-footheight,B, 0,
footheight, B, 0
SLAB 4, topheight,
0, footheight, 0,
A, footheight, 0,
A, B-footheight, 0,
0, B-footheight, 0
ENDGROUP
PLACEGROUP "topsection"
GROUP "topgrooves"
!groove1
ADDX footheight
ADDY -nudge
SLAB 4, topheight+(nudge*2),
0, 0, -nudge,
GrooveWidth, 0, -nudge,
GrooveWidth, GrooveDepth, -nudge,
0, GrooveDepth, -nudge
Del 2
!groove2
ADDY-nudge
0, 0, -nudge,
0, GrooveDepth+nudge, -nudge
Del 2
!groove3
ADDY B - (GrooveDepth-nudge)
0, 0, -nudge,
Del 2
!groove4
ADDX footheight
0, 0, -nudge,
Del 2
ENDGROUP
PLACEGROUP "topgrooves"
topsection = SUBGROUP ('topsection', 'topgrooves')
del top
RETURN
I've adjusted the positions and dimensions of the cutting grooves so that they project through the target geometry, but there's no solid subtraction happening - unless I'm missing something.
This is the resulting object:
I'm doing something wrong, I'm just not sure exactly what...
2023-02-20 08:55 PM - edited 2023-02-20 08:58 PM
Now you've made the opposite error! Your last PLACEGROUP of course must not have the quotes 😉
If unsure: just reread my first post.
EDIT: Also I'm not sure why you place the group which is used for the subtraction. If you only did this temporarily for debugging, then it's fine.
2023-02-20 09:21 PM
check you last line must looks like it
topcomplete = SUBGROUP ("topsection", "topgrooves")
2023-02-21 01:52 AM
you may just want to just place the result of the subgroup...
placegroup subgroup("topsection","topgrooves")
remember to killgroup all groups at the end of the code.
killgroup "topsection"
killgroup "topgrooves"
"top":
GROUP "topsection"
material mat2
!curved corner 1
ADDY footheight
del 2
!curved corner 2
ADDX A-footheight
ADDY footheight
del 2
!curved corner 3
ADDX footheight
ADDY B-footheight
del 2
!curved corner 4
ADDX A-footheight
ADDY B-footheight
del 2
SLAB 4, topheight,
footheight, 0, 0,
A-footheight,0, 0,
A-footheight,B, 0,
footheight, B, 0
SLAB 4, topheight,
0, footheight, 0,
A, footheight, 0,
A, B-footheight, 0,
0, B-footheight, 0
ENDGROUP
GROUP "topgrooves"
!groove1
material mat3
ADDX footheight
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 1
!groove2
material mat3
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 1
!groove3
material mat3
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 2
!groove4
material mat2
ADDX footheight
ADDY B- GrooveDepth
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 2
ENDGROUP
placegroup SUBGROUP ("topsection", "topgrooves")
del top
RETURN
2023-02-21 05:30 PM
Thanks - I thought that the duplicate PLACEGROUP statements would create duplicate geometry, but the solid operation was not functioning, so when they were omitted, I had no geometry!
I got caught out by use of single and double quotes, and no quotes at all.
2023-02-21 05:57 PM
placegroup subgroup("topsection","topgrooves") doesn't work for me in AC25, I get this message:
Keywords can't be used as variables at line 229 in the 3D script of file BYD Battery Box LVS.gsm
2023-02-21 06:10 PM
then change your groups name. i guess "topsection" is a reserved word
2023-02-22 03:18 AM
Try ...
topgroup = subgroup("topsection","topgrooves")
placegroup topgroup
