GDL
Problem with SUBGROUP
Jim Allen
I'm building a parametric component for a modular battery storage unit. Everything works in terms of basic geometry creation, but I want to finish the component with some additional details - recessed handles and grooves.
This is what the 'dumb' component looks like:
This is the parametric one:
I need to undertake a subtraction to create the grooves and handles. I've created groups, and looked up the SUBGROUP syntax, but I'm getting an error.
This is my script:
"top":
GROUP "topsection"
ADDZ (footheight*2) + baseheight + modoffset +((modoffset + modheight)* modcopies)
material mat2
!curved corner 1
ADDX footheight !footheight is same dimension as corner radius
ADDY footheight
CYLIND topheight, footheight
del 2
!curved corner 2
ADDX A-footheight
ADDY footheight
del 2
!curved corner 3
ADDX footheight
ADDY B-footheight
del 2
!curved corner 4
ADDX A-footheight
ADDY B-footheight
del 2
SLAB 4, topheight,
footheight, 0, 0,
A-footheight,0, 0,
A-footheight,B, 0,
footheight, B, 0
SLAB 4, topheight,
0, footheight, 0,
A, footheight, 0,
A, B-footheight, 0,
0, B-footheight, 0
ENDGROUP
GROUP "topgrooves"
!groove1
material mat3
ADDX footheight
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
GrooveWidth, GrooveDepth, 0,
0, GrooveDepth, 0
Del 1
!groove2
material mat3
ADDX A - GrooveWidth - footheight
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 1
!groove3
material mat3
ADDY B - GrooveDepth
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 2
!groove4
material mat2
ADDX footheight
ADDY B- GrooveDepth
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 2
ENDGROUP
topcomplete = SUBGROUP (topsection, topgrooves)
del top
RETURN
I've checked the syntax, but when I run the Check Script function, I get this error:
Group name or group type expression required at line 249 in the 3D script of file BYD Battery Box LVS.gsm.
I'm not sure what I'm doing wrong - any ideas?
Archicad 28 UKI | OS X 14.7 Sonoma
Now you've made the opposite error! Your last PLACEGROUP of course must not have the quotes 😉
If unsure: just reread my first post.
EDIT: Also I'm not sure why you place the group which is used for the subtraction. If you only did this temporarily for debugging, then it's fine.
11 REPLIES 11
runxel
Hero
There are actually two types of groups.
  1. Groups you have created with the GROUP command, which you will refer to with a string: "my group" (can have spaces)
  2. Groups that result from a compound command, like SUBGROUP.
The result of the latter will be stored inside a variable – kind of like a function in other languages.
Funfact: VARTYPE will show type 2 for this variable (means string!), but you can not actually do string operations with this. Instead this works like a pointer to the resulting geometry stored in memory.
So check your SUBGROUP command: You use variables in error here, instead the names would need to be wrapped in quotes.
Happy coding!
Thanks, I've fixed the group definitions, and amended the SUBGROUP syntax, but it's not working.
There are no errors, and the geometry is displaying correctly - except the geometry subtraction.
This is the script:
"top":
!ADDZ (footheight*2) + baseheight +((modoffset + modheight)* modcopies)
GROUP "topsection"
material mat2
!curved corner 1
ADDY footheight
del 2
!curved corner 2
ADDX A-footheight
ADDY footheight
del 2
!curved corner 3
ADDX footheight
ADDY B-footheight
del 2
!curved corner 4
ADDX A-footheight
ADDY B-footheight
del 2
SLAB 4, topheight,
footheight, 0, 0,
A-footheight,0, 0,
A-footheight,B, 0,
footheight, B, 0
SLAB 4, topheight,
0, footheight, 0,
A, footheight, 0,
A, B-footheight, 0,
0, B-footheight, 0
ENDGROUP
PLACEGROUP "topsection"
GROUP "topgrooves"
!groove1
ADDX footheight
ADDY -nudge
SLAB 4, topheight+(nudge*2),
0, 0, -nudge,
GrooveWidth, 0, -nudge,
GrooveWidth, GrooveDepth, -nudge,
0, GrooveDepth, -nudge
Del 2
!groove2
ADDY-nudge
0, 0, -nudge,
0, GrooveDepth+nudge, -nudge
Del 2
!groove3
ADDY B - (GrooveDepth-nudge)
0, 0, -nudge,
Del 2
!groove4
ADDX footheight
0, 0, -nudge,
Del 2
ENDGROUP
PLACEGROUP "topgrooves"
topsection = SUBGROUP ('topsection', 'topgrooves')
del top
RETURN
I've adjusted the positions and dimensions of the cutting grooves so that they project through the target geometry, but there's no solid subtraction happening - unless I'm missing something.
This is the resulting object:
I'm doing something wrong, I'm just not sure exactly what... 
Jorge_Arreguin
check you last line must looks like it
topcomplete = SUBGROUP ("topsection", "topgrooves")
AllanP
you may just want to just place the result of the subgroup...
placegroup subgroup("topsection","topgrooves")
remember to killgroup all groups at the end of the code.
killgroup "topsection"
killgroup "topgrooves"
"top":
GROUP "topsection"
material mat2
!curved corner 1
ADDY footheight
del 2
!curved corner 2
ADDX A-footheight
ADDY footheight
del 2
!curved corner 3
ADDX footheight
ADDY B-footheight
del 2
!curved corner 4
ADDX A-footheight
ADDY B-footheight
del 2
SLAB 4, topheight,
footheight, 0, 0,
A-footheight,0, 0,
A-footheight,B, 0,
footheight, B, 0
SLAB 4, topheight,
0, footheight, 0,
A, footheight, 0,
A, B-footheight, 0,
0, B-footheight, 0
ENDGROUP
GROUP "topgrooves"
!groove1
material mat3
ADDX footheight
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 1
!groove2
material mat3
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 1
!groove3
material mat3
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 2
!groove4
material mat2
ADDX footheight
ADDY B- GrooveDepth
SLAB 4, topheight,
0, 0, 0,
GrooveWidth, 0, 0,
0, GrooveDepth, 0
Del 2
ENDGROUP
placegroup SUBGROUP ("topsection", "topgrooves")
del top
RETURN
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration to Graphisoft. Melbourne, Australia
Thanks - I thought that the duplicate PLACEGROUP statements would create duplicate geometry, but the solid operation was not functioning, so when they were omitted, I had no geometry!
I got caught out by use of single and double quotes, and no quotes at all.
placegroup subgroup("topsection","topgrooves") doesn't work for me in AC25, I get this message:
Keywords can't be used as variables at line 229 in the 3D script of file BYD Battery Box LVS.gsm
then change your groups name. i guess "topsection" is a reserved word
AC 22, 24 | Win 10
Try ...
topgroup =  subgroup("topsection","topgrooves")
placegroup topgroup
