2016-08-2312:32 PM - last edited on 2023-05-3012:25 PM by Rubia Torres
We have just (yesterday) moved to AC20 INT 3012.
Unfortunately I've found first annoying bug (?).
When I shift 3d section plane on floor plan and go back to 3d window,
section doesn't move (doesnt redraw).
I have noticed that it will only work when I close 3d window and reopen it.
In AC19 I didnt have to close 3d window.
In the Elevation Settings Dialog what is the "Status" field set to?
It will update automatically only if it is set to the "Auto-rebuild Model" option. With the other two options you have to update it manually.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
A user in my region previously reported this to Technical Support and it was entered as a bug. It should be working properly again soon with the first mainstream Update for ARCHICAD 20 set to be released this Fall. Sorry for the inconvenience.
