‎2018-06-12
07:24 PM
‎2023-05-26
02:24 AM
Gordana Radonic
Solved! Go to Solution.
‎2018-06-13 02:56 AM
‎2018-06-14 05:46 PM
‎2021-06-08 04:16 PM
‎2021-06-09 03:43 AM
‎2022-11-29 03:31 AM
Running into this issue in Archicad 24. No change is drawing orientation is working. left-right, right-left, clock-wise, counter clock-wise. It's all opposite of what I need, cloud being on the outside of my 'Change Cloud'.
‎2022-11-29 05:00 AM
If you are using line tool (single line or rectangle) to draw the cloud, then just reverse the direction you draw.
Same for a polyline.
If using a fill, again just draw in the opposite direction.
Maybe you can post some screen shots if you are still having trouble.
‎2023-03-17 06:53 AM
The clockwise or anticlockwise method appears to work for polylines, but the change clouds are always inverted no matter what. Is there any other solution? The P key should work as a logical UIX point...
‎2023-03-17 07:25 AM
I am not going to be of much help I am afraid.
I have never used the Change Manager if that is what you are using.
If I get a chance later, I will look into how it works.
Otherwise if someone else can help, please do.
‎2023-03-20 12:19 AM
OK Thank you, I might just make a new linetype that is inverted.
