Document & Visualize forum
Dimensions shown on all levels
scsp
I was wondering if there was a way to dimension a floor plan and have that dimension string show up on all levels. For example, I would like the dimensions for all exterior building walls to show up on all levels as well as the dimensions of the elevator shaft. (I don't plan on doing a structural grid on this plan).
Thanks!
scsp
1 REPLY 1
sinceV6
Hi.
One way is to use an object and set it to display on all levels.
You can use one of the first two objects from this bimcomponents.com search.
