‎2021-08-31
04:27 AM
‎2023-05-22
11:50 PM
Gordana Radonic
‎2021-09-02 06:06 PM
Hi.
One way is to use an object and set it to display on all levels.
You can use one of the first two objects from this bimcomponents.com search.
‎2022-01-11 08:14 AM
I tried this and it seems to not work. It only shows on one level. It is gray and hard to read. It only dimensions in Metric. Is there a way to adjust this? I need dual Metric and Feet Inches.
‎2022-01-11 09:25 AM
You could isolate the dimensions on a separate layer, create a view with just that layer displayed and then overlay the view on your layout sheet.
‎2022-09-07 08:00 AM
This trick should work for you:
Dimension one floor level with all of the dimensions you need. Then go to 'Edit Elements by Stories' which is found under the 'Design' menu. Untick all except for your Dimensions. Choose the levels you wish to have them duplicated on. The dimensions will be replicated on every level and remain associated to the walls on that level. See attached.
