Project data & BIM
Merge uniform items missing?
qingdom
I can't find merge uniform items in schedule in AC26?
I only have merge items which merges everything and i don't know why would anyone merge everything that is not the same.
Did the setting move?
AC27 INT | WIN10
This is the link to the help article that explains it all in more detail.
https://help.Graphisoft.com/AC/26/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC26_Help%2F050_Views...
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
14 REPLIES 14
If you can share a s screenshot of schedule without merging?
AC 27 INT 5003/WIN 11
Of course.
AC27 INT | WIN10
I see the second column showing no. 1 should be eliminated as they are sharing the same property, that will eliminate merging all together.
But i want to merge them if they are the same size, and i want to show the quantity.
For example if there are 5 beams with same length, those 5 would merge and write 5.
AC27 INT | WIN10
Simply go to the size field and display the flag icon so it will give you a sub-total quantity and size for the merged beams.
One of the enhancements to AC26 was to do with the ability to add more control to merging of elements in schedules. I haven’t used it yet so not sure how it works.
Lee Hankins
the ability to add more control to merging of elements in schedules )
thanks @Lee Hankins @for the info and I hope you highlight that more even with a link or a screenshot.
Lee Hankins
Having hit the merge all it merges all even those who are not the same, i don't want to merge all, only the uniform items. I did click the flag, nothing happens.
Attached screenshot after i hit merge and flag.
AC27 INT | WIN10
