Hello Camille and welcome to Archicad and this forum.
Firstly please try and post in an appropriate section of the forum.
Please read the descriptions to find a section that suits your topic.
I have moved this post to the 'Construction Document' section as you are inquiring about altering how the documentation looks.
I guess it could also have gone in the 'Library/Library Parts' section as it is referring to library parts.
Anyway, unfortunately there is no easy solution to your problem.
The objects (doors) are scripted to look a certain way for each of the 2D representation settings.
With a bit of GDL coding, it would be possible to alter each object so you can adjust how it looks for each 2D representation.
But that is not really feasible with the default Graphisoft objects - you will never be able to update to a new library in future (without re-scripting all of the changes again).
If you feel really strongly about this, you could make a post in the 'Wishes' section asking for the ability to customise the 2D representation settings for objects.
You can even add a poll so other members can vote.
