Document & Visualize forum
Objects locked
Srinivas
Namaste,
I received a file to do some construction documentation, some of the objects are locked and not able to make any changes to it, I relinked the hot link modules and even deleted them to see if that will have any impact, but none, am I missing anything?
Thanks in advance for all your time.
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
4 REPLIES 4
Are they locked in the actual hotlink module?
i.e. open the module and edit them there.
Or are they MEP objects and you do not have a MEP license?
I am not sure if this locks them but I know they can't be edited if you don't have a MEP license.
Versions 6.5 to 25
Srinivas
Thank you, I will get it confirmed, I am sure, those objects are not from hotlink module, as they are appearing even after deleting the modules from the hotlink manager.
ArchiCAD Services
iMac, Windows 10
Erwin Edel
Have you tried Edit > Locking > Unlock?
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Eduardo Rolon
The lock might come from opening a file that had MEP modeler in another that does not. So you will need to unlock the objects.
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro M1 Max 64GB ram
OS X 10.XX latest
AC26 US/INT -> AC08
Puerto Rico, BVI, Miami
Vectorworks 2023
