2020-08-14 05:34 PM
2021-05-24 09:31 PM
rszabo wrote:Hi,
Please note that the next-generation mobile app doesn't use the precalculated Global Illumination at all. It applies a real-time lighting calculation algorithm instead, called Ambient Occlusion. This way, publishing and updating Hyper-models from Archicad can be multiple times faster without GI.
We are aware that the Parallel projection and Stereo 3D features would be great in the renewed app. I administrated your requests in our system accordingly. Hopefully, these functions will be implemented soon.
2021-05-28 02:35 PM
2021-06-17 01:24 PM
2021-06-17 05:11 PM
2021-06-20 09:05 AM
2021-06-20 09:13 AM
rszabo wrote:It seems to me that the BIMx app is the default app over Legacy. I could be wrong though. I uninstalled BIMx so I'd have to install again to check.
If BIMx and BIMx (legacy) are both on the device, BIMx (legacy) will be the default app for downloading from the Transfer Site regardless of the order of installations. There are workarounds for overriding the associated app to BIMx (see this example).
2021-06-23 01:43 PM
2021-07-13 03:30 AM
rszabo wrote:Thanks Roland, I understand, but I feel that if it continues to pop up, it will lead to unintended updates, since BIMx Legacy is a "fix" or a workaround to circumvent the deleted features in the standard BIMx app and is installed "purposely" in lieu of BIMx. Giving the end user the unneeded prompt to download BIMx can only complicate things they proceed. I humbly request you reconsider taking away this prompt. Otherwise, it's just another fly in the ointment for those of us with clients using BIMx Legacy (so the previous features and old GI are accessible).
Hi Rex,Sorry to hear the page about switching from the retired app causes such inconveniences. This page appears at first launch, and then only once every 30 days.
rszabo wrote:If I may ask, why is it only "possible?" Wouldn't it be beneficial to have these features back to make this app full featured. The current BIMx has so many limitations without 3D mode or parallel views.
Stereo 3D and Parallel Projection are on the list of possible future developments, and we will consider improving the design of BIMx Model Transfer Site too.
rszabo wrote:Yes, going from email, to web browser, to an unintended browser UI, then to app, is not a good process. The email should contain a direct download link that opens in the app.
Providing download links to clients is a nice solution to make the import process simpler by not touching the web UI, since the best functionalities are in the mobile app.
2021-08-05 04:15 PM
2021-08-12 09:23 AM
Florian wrote:I truly feel it will not happen. It's been a year since the BIMx update where they took out the higher quality renderings, parallel views and 3D stereo vision and to date, we've seen no improvements. I think Graphisoft has painted themselves in a corner and that R&D has no solution.
hi,
does anyone know when the update of the visual enhancements (GI, AO,...) will come for BIMX?
The current visual quality is of a kind that we prefer not to use BIMX as presentation tool for clients.
Hope improvements come soon.
BR, Florian
