2x2 ceiling fill printing problem
dhnguyen
I'm not sure why when I print out my reflected ceiling plan, my 2x2 ceiling fill comes out funny--- has anyone has this problem and how did you solve it?
Even if i changed my pen weight from .05mm to .15mm, it does not make a difference.
attached are 2 different images, 1 is a pdf and the other one is a hard copy.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
12 REPLIES 12
Did you print it by a Publication/Draw, by Files/Print, by Files/Draw or by printing a PDF with an external viewer ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
dhnguyen
I used the navigator to publish the pdf, then i print it to the plotter (HPDESIGN JET)
DNguyen
ArchiCAD 18- 25
I am not surprised then. The subject seems to me more to be the printer driver of your plotter HP rather than Archicad. Also it would seem to me more relevant to use the Archicad plot function than the print function.
What is you paper size we can see on your picture ?
Have a nice day ,
Christophe - FRANCE
dhnguyen
it's 30" x 42" - see attached
DNguyen
ArchiCAD 18- 25
Print is more for A4, A3 and other little paper size
All taller paper size have to be plot and not print to have better result
Try and tell us ◔_◔
Christophe - FRANCE
Erwin Edel
Sorry, but I have to disagree. Most large format printers are excactly that: a printer. The plot function is not well suited for these machines.
We've been printing to our large format machines since about AC10 when plotmaker was obsolete and we got a new Océ TCS500 at the time.
Currently we have Canon machine and we use print for that too.
Printing directly from Archicad yields better and faster results than publishing to PDF and printing that, by the way. At least in my experience with several large format printers.
Just set up a printing publishing set.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Of course !
All is written here :
https://helpcenter.graphisoft.com/knowledgebase/25620/
Christophe - FRANCE
dhnguyen
Thank you for your responses, printing the drawing directly to the plotter solves this problem, however, if I send the drawing to consultants as a PDF, this option takes forever to print to PDF. It has been 20 minutes and I still haven't been able to print to PDF-- not sure why. I changed my dpi to 300 to speed up the process but it doesn't seem to work.
DNguyen
ArchiCAD 18- 25
Today and since few years there is no real solution to print a heavy pdf which have got a lot of hatch : for a lot of software and I don't know why.
You can also transform your vectorial pdf into a bitmap pdf to be sure it could be print easier than you original pdf but... It's not a vectoriel file ! 😕
I dream about a new archicad function to do that !
Christophe - FRANCE
