3D document parameters, shading using texture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2025-01-23
03:59 AM
2025-01-29
01:42 AM
I would like to add a shading function for 3D objects in documents using textures
- Labels:
3D Document
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-01-27 09:48 AM
It is not possible to make 3d documents with textures. This is only available for orthogonal views (elevations & sections).
Workaround is to save a 3d view. Right click in the 3d view to change the settings.
An export of a 3d view has low resolution, if you need a higher resolution you'll have to put a camera and save the camera as a view. Set the resolution in de viewsettings of the camera.
minimal resolution (150dpi) for A3 = 2480x1754 pixels high resolution for A3 (300dpi) = 4961x3508
AC27
