canvea
3D view placed on layout is blank
I have a problem with 3d views showing up as white/blank when placed on a layout. I have tried Fit frame to Drawing, Full Precision Preview etc and they are on Auto-update. If I right-click and pick "Open source view" it looks just as it should in the 3D window. They also appear blank when I publish, which is a big problem. Am I doing something wrong or is this a bug?
Thanks in advance for any response!
Archicad 23, Windows 10 Pro, graphics card: NVIDIA Quadro P4000
AC24 Norway • Fujitsu • Intel(R) Xeon(R) W-2123 CPU @ 3.60GHz • 32GB ram • Windows 10 Pro • NVIDIA Quadro P4000
47 Replies 47
DAC
This is still happening in 2024. I note that the last input from Graphisoft on this post was in 2021 - a generic response and no feedback after thier Q's were answered.
This is costing us all time we have not got and, at the last stage of publication when the stakes are higher.
Come on GS
Mats Knutsson
Still in 27...(bad word of choice put here)
HP ZBook Fury 15,6 G8. 11gen i7-11800H 2.3GHz. 32 GB RAM. Nvidia RTX A3000 1GB. AC22-27 SWE.
cuba
Open the drawing selection settings and switch between Fit frame to drawing and manually resize frame. (+ fit in window)
Had this issue on windows + mac laptops.
Apple M1 Max 32 GB
Latest AC
benjamin_chan1
Glad to know I'm not the only one still facing this issue (and on AC27)
Cuba - does switching between Fit to frame and Manually resized frame fix the issue for you?
cuba
It does not always occur. If you have an empty frame, the drawing without a frame does appear somewhere far outside the drawing. By switching, the frame is around the drawing again, but it may be outside the layout. You just have to move it then. Sometimes this happens for several drawings on a layout, sometimes there is no problem. (only happend on ac27)
Apple M1 Max 32 GB
Latest AC
Mats Knutsson
Nothing worked...except turning off and on the computer and change to fit frame to drawing...
Gerry Leonor
had the exact issue with a guy in our office just then. placing a saved 3D window view into the layout resulted in a blank drawing. nothing worked. messing with the Drawing boundary & zoom didn't do anything. opening the source view (3D window) was OK -- no issues at all. pretty much everything that's been discussed in this thread.
the solution i proposed was to use a 3D Document version of the 3D view. this fixed it & the empty drawing error doesn't happen anymore.
https://discord.gg/XGHjyvutt8
Did you guys try it with the latest Ac27 Update that just came out?
Gerry Leonor
apologies -- i should've mentioned, we're in 25, in the earlier response. can't say for everyone else.
cuba
Updating did not help....
Apple M1 Max 32 GB
Latest AC
