canvea
3D view placed on layout is blank
I have a problem with 3d views showing up as white/blank when placed on a layout. I have tried Fit frame to Drawing, Full Precision Preview etc and they are on Auto-update. If I right-click and pick "Open source view" it looks just as it should in the 3D window. They also appear blank when I publish, which is a big problem. Am I doing something wrong or is this a bug?
Thanks in advance for any response!
Archicad 23, Windows 10 Pro, graphics card: NVIDIA Quadro P4000
AC24 Norway • Fujitsu • Intel(R) Xeon(R) W-2123 CPU @ 3.60GHz • 32GB ram • Windows 10 Pro • NVIDIA Quadro P4000
47 Replies 47
Mats Knutsson
Still not working.
HP ZBook Fury 15,6 G8. 11gen i7-11800H 2.3GHz. 32 GB RAM. Nvidia RTX A3000 1GB. AC22-27 SWE.
Zdenko
placed several yesterday to show client and they requested additional 3d views. i am sitting here now trying to figure out why they are all blank as described above. i find myself doing screen captures and sending for review.
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
Patrick M
Ace
yeah, it's super annoying and a bit embarassing that this is still a problem. I have resorted to only using 3d documents as 3d views on the layout
Melissa F
If anyone is still having issues with this problem I think I've found a fix.
Try this: close the archicad file, then reopen and select "open and repair file" when opening.
AC25 International
Mac Studio 2022, Apple M1 Ultra, 128GB RAM
13.1 macOS Ventura
AC since version 4.5
Bergark
Beginner
Open and repair file solved the problem for me! 👏
PB
Thank you Melissa - you've saved the day for me !
Frankly disappointing that this is still an issue in Archicad 29...
AC29. Twinmotion.
16" M1 Max MacBook Pro 32GB, Apple Studio Display, MacOS 26 Tahoe
Patrick M
Ace
closing archicad, restarting your computer does the same as open/repair... Its all just a temporary fix, as it'll definitely pop up again.
Restarting your computer simply resets the computer memory and may be the solution for some problems - it may have fixed this problem for example.
The 'Open & Repair' option when opening a file goes a little deeper and will actually fix problems in the file itself.
