2006-06-09
08:13 PM
2023-05-26
02:35 AM
Gordana Radonic
2006-07-07 06:38 AM
2006-07-07 06:52 AM
I having been using Fit Frame now that AC seems to acknowledge the Zoom saved with the view settings (never worked for me in v9).Hey Owen,
Seriously I hope this is going to get fixed in a patch.Me too. Should find out soon enough.
It is a real pain in the arse when working on big drawingsSay it like you mean it, brother.
2006-07-07 07:19 AM
Link wrote:Yeah sorry i could have been clearer. I know a drawing should not be Fit to Frame if it has a zoomed area saved (and Fit to Frame if not) - I just never seemed to get this to work in PM9.I having been using Fit Frame now that AC seems to acknowledge the Zoom saved with the view settings (never worked for me in v9).Hey Owen,
It's actually always been dependent on the views' Zooming. If you saved with Current Zoom, the drawing would not be Fit to Frame. If you saved with zooming set to None, it would be Fit to Frame.
This is still the case with AC10 and made more obvious by the drawing's frame when placed on a layout. Fit to Frame drawings will have a frame with a solid line and Manually resized frame drawings will have a frame with a dashed line. That's if you have drawing frames visible in On-screen View Options. Fit to Frame is the only way to go IMHO.
The visual clues are welcome that's for sure.
Link wrote:Thought that would have me bleeped. Anyway I think i made my feelings known in a few of the other posts on this subject. I have relaxed a little now
It is a real pain in the arse when working on big drawingsSay it like you mean it, brother.![]()
2006-07-07 07:44 AM
Setting myself up here again i think but even with the Adjust Drawing Frame of imported vectorial drawing to reflect ArchiCAD view's zoomed area checked (see attached) it would only ever place a drawing showing the entire contents, not the views zoomed area. Is there another place I should have been looking for this?Yes that's still there in AC10, under Project Preferences > Layouts. This is a global setting, which is on by default. If you turn it off, none of what I said earlier is relevant.
I havent checked in 10 but if your placed drawing is based on the views zoom and you change the zoom, does the frame change on the layout? I guess not but it would be a good option .. sort of Fit Frame to Zoom. Generally we use Fit Frame to Drawing but for plans you often need to use the views zoom so this feature would be very helpful, particularly for zone plans.No it doesn't, which is why it is typically a dangerous state. If the view is saved with a Zoom, it's frame will be set to Manually resized frame, and that means just that. So if the zoom is changed, the drawing's frame won't be updated to reflect it because it's 'static'.
2006-07-26 02:14 AM
