2023-09-20 09:59 AM - edited 2023-09-20 10:00 AM
Hi all!
Have a problem with "Webdings" font in AC 25
When I open text and put the symbol everything is OK, but when you exit out of the text it is not showing correctly...
I tried to make a GDL symbol but same thing happens... Is there any bypass / solution to this?
P.S. I tried to do the same thing in AC 26 and it works but I don't want to convert my file to newer version.
2023-09-20 10:27 AM
I am not sure what could be the problem.It is working fine for me in 25.
Do you have the latest update for 25? (build 7000).
What happens if you save a 26 file back as a 25?
It can't be a font issue if it is working for you in 26 on the same machine.
2023-09-20 10:47 AM
Ok my AC is at build 3011, however my colleague has the same build and it works fine.
I tried to save a 26 back to 25.
In 26 shows up OK in 25 NO...
2023-09-20 10:59 AM
I have no idea why it would not work on your one particular machine - especially when it does work with 26.
I always say make sure you have the latest build, but I don't think that is the cause either.
Seems doubly odd that you can see it in the text editor but not on the screen.
Sounds like an e-mail to your local Archicad support people if you have a support agreement.
2023-09-20 11:04 AM - edited 2023-09-20 11:14 AM
Yes ok, thank you four your troubles.
I also tried to launch ac 25 in default profile and template but still no luck 🤷
