Domagoj Lukinic
AC 25 "Webdings" font
Hi all!
Have a problem with "Webdings" font in AC 25
When I open text and put the symbol everything is OK, but when you exit out of the text it is not showing correctly...
I tried to make a GDL symbol but same thing happens... Is there any bypass / solution to this?
P.S. I tried to do the same thing in AC 26 and it works but I don't want to convert my file to newer version.
DomagojLukinic_0-1695196404495.pngDomagojLukinic_1-1695196435158.pngDomagojLukinic_2-1695196442952.png
1 Solution
I have no idea why it would not work on your one particular machine - especially when it does work with 26.
I always say make sure you have the latest build, but I don't think that is the cause either.
Seems doubly odd that you can see it in the text editor but not on the screen.
Sounds like an e-mail to your local Archicad support people if you have a support agreement.
Go to post
4 Replies 4
I am not sure what could be the problem.It is working fine for me in 25.
Do you have the latest update for 25? (build 7000).
What happens if you save a 26 file back as a 25?
It can't be a font issue if it is working for you in 26 on the same machine.
Domagoj Lukinic
Ok my AC is at build 3011, however my colleague has the same build and it works fine.
I tried to save a 26 back to 25.
In 26 shows up OK in 25 NO...
Domagoj Lukinic
Yes ok, thank you four your troubles.
I also tried to launch ac 25 in default profile and template but still no luck 🤷‍
