AC17- Merge DWG into Layout duplicates Pspace Xref Elements
Eduardo Rolon
I have been Merging DWGs to Layout with the following strange results.
If the DWG has a placed XRef in Pspace AC will create a duplicate of the XRef after import, there are no duplicates in the DWG file.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
After 'Append to Layout'
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Thought that the reason for the duplicate was that the XRef has the same information on Mspace and Pspace and AC is importing both.
Removing one of the copies does not solve the problem.
Curious.
AC29 US/INT -> AC08
another Moderator
