2023-04-27 03:34 PM - last edited on 2023-05-09 03:15 PM by Gordana Radonic
Attached is a screenshot showing a fraction that I "constructed" using several texts. How can I add a fraction in using the text tool?
Solved! Go to Solution.
2023-04-27 04:09 PM
For certain fractions, you can try typing the ASCII code.
¼ = ALT+0188
½ = ALT+0189
¾ = ALT+0190
That is hold the ALT key while typing the number.
Otherwise use the Character Map (it is a Windows Accessory) and you can copy and paste those characters.
But only those 3 fractions that I know of.
2023-04-27 04:20 PM
Thank you, Barry. Is there an ASCII code that helps with roof pitches? As you can see in the below copied screenshot, I used three text boxes to indicate the roof pitch (0.5/12). I have a fraction (1/2) in the nominator!
2023-04-27 04:29 PM
There are only those 3 ASCII codes that I know of.
It just means you can type ½ as one character instead of 1/2.
So the best you could do is ½/12
To have the text vertically above and below as you have shown, you will need two separate text boxes or one text box with a carriage return (enter) and set the top line with underscore style maybe?
I don't have Archicad running at the moment to try anything.
2023-04-27 11:52 PM
FYI:
You can create a fraction in Unicode by using a superscript code + fraction slash (U + 2014) + subscript.
Or you could just use a fraction generator site as in:
2023-05-02 04:39 AM
Just wondering, why would you put a fraction in a fraction and not just simplify it down?
AC22-28 AUS 3001 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2023-05-02 05:57 PM
It is a standard that we follow.
2023-04-27 04:09 PM
¼ = ALT+0188
½ = ALT+0189
¾ = ALT+0190
2023-04-27 04:20 PM
2023-04-27 04:29 PM
2023-04-27 04:31 PM
Thank you, Barry!
2023-04-27 11:52 PM
FYI:
2023-05-01 05:34 PM
Thank you, Gerry, I would need to learn how to "code" in ArchiCAD. Could you share a tutorial?
My aim is to learn how to type the nominator as a fraction.
2023-05-02 04:39 AM
2023-05-02 05:57 PM
