Since you are comparing a sum total of a set of zones (or fills, not sure which it is) to another single one, I don't think this calculation can be done with properties. Since properties are set for a single element.
We do these sort of calculations in Excel, since we need to derive a lot more calculations from the square meters of a project. That does mean manually typing in the values in excel initially, but even with large appartment projects that rarely means more than a few stories and appartment types.
You can also add dummy text fields to schedules where you can just type values if you don't like adding the text to layout.
www.leloup.nlArchiCAD 9-29NED FULL
Adobe Design Premium CS5
