ArchiCAD 22 - copy and paste within text boxes
Hi All,
I am having an issue where i am trying to copy partial text within a text box and paste it into another text box. It looks like the text doesn't even copy to the clipboard when I select "copy" and hence when I paste there is nothing! My colleague has the same problem. We are using ArchiCAD 22. If we copy and paste text from elsewhere, such as Notepad, it seems to work fine. It only happens when trying to copy from text box to text box within ArchiCAD. Is this a bug? Has anyone else had this issue?
Thanks
55 REPLIES 55
Works for me correctly.
(Click the GIF to play the animation)
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
Hi, Mine still isn't working. Click on GIF below.
Stress Co_
Off topic:
How are you guys creating the GIF's?
On topic:
Does restarting your computer have any affect?
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina)
Processor: 3.6 GHz 8-Core Intel Core i9
Memory: 48 GB 2667 MHz DDR4
Graphics: Radeon Pro 580X 8GB
ArchiCAD 25 (5010 USA Full)
off topic - use an app like "Screen to GIF" you can search for it.
on topic - yes I have tried re-starting but no luck
Stress Co_
No ideas... works for me in AC22.
I am using SnagIt 2020 Full version.
That is curious. Try to install the latest AC22 update if you have not already. Let's see if that helps.
I have AC20, 21 & 22. It happens in all these versions. The clipboard seems to working fins with other programs for text - it's seems it's only AC where text doesn't copy and paste.
I am wondering if this may be caused by some interference by another program.
Try to restart your system, then exit all applications that are not needed.
Then check if copy-paste works, because if it does then some other app is interfering with copy-paste or the clipboard somehow.
