Saturday
One for the Way Back Machine, but I'm trying to open a LBK file from Archicad 11 using AC 26 but AC26 crashes every time.
Anyone have any thoughts on how I can open this old LBK file?
Thanks in Advance,
Joel
yesterday
I’m not sure if it works for a Layout Book. If you open Archicad first then navigate to the Layout Book file you want to open and make sure you select the checkbox to repair the file if it’s available for Layout Books, that might work.
12 hours ago
Just did a test with a 8.1 version.
The AC file opened without issues and the saved views were there.
Trying to open the LBK crashes AC.
The LBK couldn't be merged.
No repair option in AC26.
another Moderator
12 hours ago - last edited 11 hours ago
Try Archicad 25
https://help.graphisoft.com/AC/26/INT/Archicad.pdf
i don't know if going to an earlier version will help.
