Archicad won't save a file as PDF
Cosmin
Hello everyone,
The problem I'm facing is that I can't save a project as a PDF.
I'm clicking on File, Save As, choosing the folder, selecting the file type (PDF), and it will just load.
If I go to Task Manager and select Archicad, it shows that the program is not responding.
Do you know how I can fix this?
Thanks.
2 ACCEPTED SOLUTIONS
Eduardo Rolon
That should not be happening unless the PDF area is either too big or has too many elements
Use the Marquee Tool (Dashed Rectangle) to draw an area and use that to publish
Check that the blue rectangle fits within the selected paper size
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
It worked , thank you very much
4 REPLIES 4
Eduardo Rolon
You cannot "save a project" as PDF.
You can save views (or what is on screen) and you can publish to PDF.
https://help.graphisoft.com/AC/27/INT/_AC27_Help/120_Interoperability/120_Interoperability-21.htm?rh...
https://help.graphisoft.com/AC/27/INT/_AC27_Help/120_Interoperability/120_Interoperability-19.htm?rh...
About program not responding. Which version are you using and is it up to date?
AC29 US/INT -> AC08
another Moderator
Im using Archicad 27
The student version
I'm trying to do what the first link you sent is explaining , but it keeps loading and nothing happens.
Eduardo Rolon
AC29 US/INT -> AC08
another Moderator
