2004-09-09 08:37 PM
2004-09-10 04:17 AM
Dan wrote:Hi Dan,
If so, can someone please suggest how I might list my windows by zones and sum their calculated light and vent values?
I assume I would need to add light and vent parameters to all my window objects - or am I overlooking a possible Global Varible(s) that may already exist for this purpose.
2004-09-13 08:09 PM
Karl wrote:karl,
All objects are 'aware' of the zone(s) that they are in, so grouping by zone should not be a problem (providing your zones don't overlap).
You don't need to introduce new variables ... use the 'User Defined' variables in the parameter group "ArchiFM and Listing Parameters" at the end of the scrollable param list in your window settings dialog. Unless you have scripts to calculate these values - they are more likely static - you might want to create your I.S.first, to group identical windows, and then fill in these fields to update all similar windows in one step.
2004-09-13 11:54 PM
Dan wrote:Yes, makes sense. I misunderstood where you were standing when you asked the question. I thought you knew that the intelligence wasn't there, and were asking for variables for you to manually enter the info so that it would appear in schedules.Karl wrote:
I hope what I'm promoting makes sense...I just cant see how you can achieve these schedules without more intelligence scripted into the standard ArchiCAD zones and Windows.
