Can't find Keynote palette
Cooldad
Hello
I work with AC28INT
I opened a project made with AC27INT and I can't find the "keynote" palette
I have the impression that by migrating my project from AC27 to AC28, ArchiCAD simply "lost" this possibility of creating keynotes
did this problem happen to you?
how did you solve it?
have a nice day
1 REPLY 1
Have you loaded your old 27 Work Environment?
If so, the new commands will not be there, you will need to add them to your menus and toolbars.
Or load the 28 default Work Environment, but then you will need to add any customisation you may have done for yourself.
Setup info provided by author
