2023-12-22
02:21 AM
2023-12-28
06:25 AM
Hi all,
For some reason the individual interior elevation won't inherit the Name defined in the parent IE Group’s settings.
It is set to “By IE Group.”
Please see a screenshot where I compare both ArchiCAD 26 and 27.
It works all fine in 26. It doesn't work in 27.
It shows correct name under "Name", but incorrect under "Reference to"
Any suggestions anyone?
6 hours ago
Thank you for this!! I guess I missed the discussion on wish list so I’ll try again after July!
I have seen the archicad schedule but does it also include the wishes that will be actually implemented?
6 hours ago
@James B , I can still replicate this issue in the latest build of AC27. I just checked. It is a particular obvious issue for interior elevation markers for which a view point has been deleted/removed. You need to "restore all viewpoints", rename, then re-delete the unwanted viewpoints
5 hours ago - last edited 4 hours ago
Hi @Patrick M
I can't replicate this yet in the latest AC27, can you help clarify the steps I need to follow? Thanks.
EDIT: Now I can replicate the problem, after discussing with Patrick offline. Will investigate further.
James.
3 hours ago
I think we’ve to wait until the review phase ends then results will be published in the same insights’ section, don’t forget to subscribe to the roadmap journey via this link.
https://community.graphisoft.com/t5/Graphisoft-Insights/bg-p/gs-insights
