2019-07-24 08:49 PM - last edited on 2023-05-17 05:34 PM by Gordana Radonic
2019-07-27 08:08 PM
2019-07-29 10:10 PM
Steve wrote:
It appears that what you are wanting to is it for a simple 2D drawing since you don't show any ridge cap on the hips or ridges. When you just want to make the roof outlines bolder you might just as well draw a line.
One way you can get those lines to be bolder is to add some ridge and assign a different pen to it. For example, the Eptar tile roof objects as shown below.
https://www.eptar.hu/cadsupport.php?id=product_block&pID=7&Lang=ENG
It's Free too
Just a tip on how to use the Terran_Topridge (ridge object) -- you adjust the angle to fit the pitch of the hips with the column icon in the pop-up 2019-07-27_11-13-49.jpg
Another good way to do that is with the Morph tool. In 3D window you can put a morph line on the ridges and that way you won't have to draw a line in every view of the roof.
