Controlling depth of Section View.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-09-01
10:49 AM
2023-05-30
12:28 PM
Rubia Torres
I have created a section through my house and i want my section view to only shot about 300mm in.
How can I do that ?
Thanks.
Ian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-09-01 11:08 AM
Good luck!
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-09-01 11:37 AM
If you choose limited you can adjust the range limit on the plan.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-09-01 01:34 PM
the complete system and help files are all in german.
so sometimes I pop up with a stupid question, but im a total starter with archicad and maybe other starters can use these treads.
Thanks a lot for the help.
Ian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-09-01 02:26 PM
aslo when i am looking at my plans, GROUND LEVEL.
I can see elements from the next upper level on the same view.
Where can i change the view height of my plan views ?
Thanks.
Ian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-09-01 03:14 PM
Then look in the navigator under project map you will see your stories for the project. You can right click on that and select story settings to control your story height. Then you need to be careful of the base distance you set any object you are placing so there are being placed at the right height above project zero. This should prevent a lot of "bleeding" between stories if you're just primarily doing 2D. But you can also refine this by again going to the info box and you will see two boxes, "Show on Stories" and "Home Story". Between these two options you can further refine the 2D display.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-09-01 03:49 PM
the first section worked perfect for me.
But with the plans, when i play with the level settings, my model just crushed up like a old chocolate bar.....
can some one help me understand, how i can ON PLAN, make it so i see only items from level 0 up 500mm.
Thanks.
Ian
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-09-01 04:45 PM
There are also some tutorials that you may find useful for a quick reference if you are trying to achieve something similar as covered in the tutorials: http://www.graphisoft.com/education/training_guides/
The story view range is controlled by Floorplan Cutplane Settings dialog window. Should be found under Document > Floor Plan Cutplane.
Do note that these settings are associated with saved views, so if you wish to change it on layouts, you need to redefine your view with the desired settings.
Besides these settings, most tools also have the option to project with or without overhead lines or to just show the cut element, outlines or overhead lines. Roofs and objects generally offer the most control over which stories items show up on.
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-09-01 07:56 PM
View>on screen view options> Marker range (so you will see the line of denoting depth of field.
Select the marker an adjust the depth line of the marker. You can do this by clicking on the node in the middle of this line, or placing your cursor along this line so the cursor shape is now a mercedes. The mercedes denotes the edge of a plane, similar to the edge of wall.
HTH
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
