‎2006-03-02
07:50 PM
‎2025-01-23
11:31 AM
Gordana Radonic
‎2006-03-07 06:14 PM
Djordje wrote:I have always had a hard time working in 3-d when drawing, placing, or even copying elements. I can edit them there with heights and size and all but not much more.
Yep.
Whoever told Sergio that you can't add in 3D is at least an ignoramus.
3D is the real working environment. Use it, guys!
‎2006-03-08 09:44 PM
Djordje wrote:Matthew wrote:
I believe Djordje was referring to the handy practice of moving the 3D user origin to the current story's elevation.
Yep.
‎2006-03-08 09:52 PM
Sergio wrote:You cannot place new 3D elements in elevations/sections. Maybe that's what you were thinking of?
nevermind the fact that I didn't think you COULD place new objects in 3D.
‎2006-03-08 10:00 PM
Joseph wrote:Here are a few of mine:
What other operations are better done in 3D instead of 2D?
Can you give a list of your know how?
‎2006-03-08 11:18 PM
Find & Select
Solid Element Operations
Trim-to-Roof
Placing Roofs at a custom angle
Placing vaulted roofs
Changing roof pitches visually
Changing Slab thicknesses visually
Placing "belts" of trim that overlap in plan, but cannot be Magic Wanded or Copied
Finding the cause of strange lines in sections/elevations
‎2006-03-09 12:09 AM
TomWaltz wrote:Tom, there is no ground to compare "SEO's" between 2D & 3D Working Environment, because of possibility to SEO only in 3D window!Joseph wrote:Here are a few of mine:
Find & Select
‎2006-03-09 12:20 AM
Joseph wrote:Addition to Tom's list:
What other operations are better don in 3D instead of 2D?
‎2006-03-09 12:26 AM
Z.Bauer wrote:Not true. You can do SEOs in plan and elevation.
‎2006-03-09 12:27 AM
Joseph wrote:Good, the bill is in the mail.
Wow Tom,
You already increased my productivity.
Thanks,
Joseph
‎2006-03-09 12:39 AM
TomWaltz wrote:My apologizes Tom,Z.Bauer wrote:Not true. You can do SEOs in plan and elevation.
