Grubenstein
Creating a Label that Reports the Layer Name
Hi All,
Has anyone worked out how to create a custom label that reports the layer name. I have some fills on a drawing that show the ownership of a site super imposed onto a 2d site plan. Each fill is on a different layer that has the Ownership Title reference. I would like to label each fill with the layer name
Any assistance would be much appreciated
Thanks
Kevin
7 Replies 7
runxel
Just use the Autotext for that.
If that is no option use rrr = request("GLOB_LAYER", "", str_layer).
Grubenstein
Hi, thanks for that.
Do I simply enter what you have written into the autotext. Doesn't seem to work.
Thanks
Why not using a Text/Autotext Label whith the layer info? Custom label seems overkill
Archicad 27 - GDL - PYTHON
Grubenstein
Hi Mathias,
Can you explain how please.
Thanks
Grubenstein
I have a lot of fills so just want to click on the fill and tag the layer name. So dont mind setting it up if thats whats needed
Stefan L_
Use the Text/Autotext label, then click on the marked button and select the appropriate entry:
Stefan - AC ...-29GER, WIN11
Grubenstein
Brilliant thank you sir!
