Thank you James, it works somewhat. I am trying to add zone names to sections. All zones have a height of at least 7'. In some cases I am able to use the autotext feature within the label to return the zone name, however when I select some rooms in section which have 7' minimum tall zones, the custom properties are not available. Is there some setting I am missing whereby custom properties are available for some zones and not for others? Thank you for any advice. Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
