aylinmelis
Custom labels does not work on sheets
Hi everyone i created custom label and its working on plan view, but on sheet does not work.
Basically if i use directly a auto text label it work, but when i create a custom label with adding symbol that i want nope..
i saw in this forum discussed before this topic for previous versions of arhicad. But now i have problem with archicad 29 and 28.
Plan view:
On sheet:
note: its not the automatic update for the view problem because its already auto..
If anyone has any solution
Thanks already!!
Operating system used: Mac Apple Silicon Tahoe 26.1
Setup info provided by author
2 Replies 2
CosminF
The label has to get his information from objects so it can autocomplete the values you are recalling.
This won't work in layout simply because in layout you only have a placed view, you can't "select" or isolate elements in that view.
Hope this makes sense.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Just to clarify.
You are placing the label in the plan view in Archicad, associated to an object.
You then place a drawing of that view on a layout page an the label no longer shows the information?
If you are placing the label directly in the layout, then it wont work.
