3 weeks ago
I am an archicad user from greece and would llike to make a custom label for windows. I have tried but can't seem to quite get it.
What I am trying to do is make a frame which will have the window id, the width on the left and on the right the sill level from the concrete slab of the relevant concrete floor slab and header. This is how we are supposed to do them in greece. I can do it with autotext but i need to click the window to obtain each info and then move it to the table. Is there an easier way to do it using labels? I am using archicad 26. (I want to do the same for doors but using a cicle. They will be measured from the top of the flooring). Thank you.
Solved! Go to Solution.
3 weeks ago - last edited 3 weeks ago
Hi @KorniliaP
I'm sure there's a more elegant way using GDL code, but here's a quick and easy method:
(Watch the attached video to see the process)
Hi @KorniliaP
3 weeks ago
- last edited
3 weeks ago
is this forum for real?
anyway, here's what i came up with (trying to) using Ricardo's elegant GDL way 🙂
Sorry, had to upload to an external site.
[Moderator: I zipped the GSM file and attached it to this post.]
3 weeks ago
- last edited
3 weeks ago
Thank you for replying.. I did the same but my label has no text when I add that to the window. Any thoughts why?
EDIT: NEVER MIND I WAS USING THE LABEL TOOL WITH AUTOTEXT AND NOT THE TEXT TOOL!
3 weeks ago
- last edited
3 weeks ago
Nice! Thanks, but unfortuntely it prints like this.
I also need the position of the info exactly as shown in the original post.
3 weeks ago
Hi @KorniliaP
Try creating the label object in the view at the scale you need. I did it in a view with a scale of 1:50 so that the label object would appear exactly as intended.
As I mentioned, this is a quick and easy method, but it has its limitations.
I’m sure someone with a good knowledge of GDL could create a proper object.
3 weeks ago
- last edited
3 weeks ago
work fine for me. I tested it in AC29. What AC version are you using?
3 weeks ago
I was mistakenly using label tool instead of simple text.. Inception! Label within a label. lol
3 weeks ago
You are a life saver!
Is there a way to edit the label should i need to change the parameters? Or I simply create the new and overide the previous one?
