Custom/specific cut fill in cut wood elements
Hello!
Is there any fastest way to integrate a sign like this (cross) on all cut wood elements, then doing it manually in 2d? https://ibb.co/sKv7PrD
If possible, I would like to have it on all rafters and beams.
I know it is possible, to achieve it with composites, but then I lose other options that a rafter for example has.
Thank you for advice!
Hello tjasaa,
You can use Patch to create a 2D dynamic 2D object you have to put on each your beams :
https://helpcenter.graphisoft.com/user-guide/88762/
Or you are able to use a complex profile by drawing a cross into your element :
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
