Cutting Plane
Hi!
How do you setting the Floor Plan Cut Plane Setting to show the second floor only without roof or anything below?
Thanks
Could you elaborate this a bit more?
You are on a given Story. What do you want to see/not see on that Story?
What do you want to see/not see on the Story Above?
What do you want to see/not see on the Story Below?
Hi! For instance, if I am cutting the second floor plan at 3' above finish floor, I want to see everything that is cut at that floor, and I don't want to see the story below " the second floor" nor do I don't want to see
the roof that has the plate at the first floor.
Thanks
Guru
With the roof below, you can just set it's Floor Plan Display as Home Story Only. Walls and such by default don't show on stories outside of home, but if they are, you can do the same to the relevant objects.
Ling.
