‎2015-12-09
10:39 PM
‎2023-05-26
02:26 AM
Gordana Radonic
‎2015-12-10 04:27 PM
rob2218 wrote:
Stuart,
I did just that.
Rotated my orientation in the model envirnment.
Then I saved my view.
Then I placed that new view on a layout and the market detail tag still will not rotate properly even after I've set the parameter in the actual marker head.
The detail marker still is rotated 90 degrees from how I need it to be.
‎2015-12-10 04:43 PM
‎2015-12-10 04:53 PM
rob2218 wrote:
Ok, I'll give it a try this morning.
‎2015-12-10 05:40 PM
‎2015-12-10 07:20 PM
rob2218 wrote:
rotating the viewmap "before" I inserted it into the layout changes/alters "some" of the tags (door and zone name tags) but didn't do poo to the detail marker tag...no matter what parameters I have set the detail marker tag to?
dunno.
‎2015-12-10 07:37 PM
‎2015-12-10 07:55 PM
rob2218 wrote:
very strange...I don't seem to have that "marker geometry" in the settings? I'm using an AC18 detail marker so I'm not sure what's up.
‎2015-12-11 02:16 AM
vgodzb wrote:
Sorry forgot to tell you to use the built-in detail marker or Detail Marker Simple.
‎2015-12-11 03:35 PM
rob2218 wrote:
really? the detail marker too was created like the "stair maker" was programmed?
where they put two groups in a room, didn't let them talk to each other and said......."create the stairs"....
‎2016-03-29 03:02 AM
