2023-06-15 06:31 PM
Is there a way to view 3 decimal places on 'Length Unit' and 'Layout Unit' in ArchiCAD 23 Solo? These options are there in Personal Preferences > Working Units but greyed out so I can't select them. Hoping there is a way to activate them through the programme or via a plug-in.
Any tips would be great!
2023-06-16 04:27 AM - edited 2023-06-16 04:27 AM
The number of decimals available depends on the units you use.
Set to meters and you can have up to 4 decimal places.
Set to millimeters and you can only have up to 1 decimal.
Effectively the same number, just a different unit of measure.
You can only see down to 0.1mm of accuracy in the dialogues - although you can type in more (you just can't see it).
2023-06-16 05:00 AM
Working Units will not change how your dimensions are shown, only how you measure and place things.
Options => Project Preferences => Dimensions
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
