Decimal places on dimensions - ArchiCAD 23
eilidhizat
Is there a way to view 3 decimal places on 'Length Unit' and 'Layout Unit' in ArchiCAD 23 Solo? These options are there in Personal Preferences > Working Units but greyed out so I can't select them. Hoping there is a way to activate them through the programme or via a plug-in.
Any tips would be great!
The number of decimals available depends on the units you use.
Set to meters and you can have up to 4 decimal places.
Set to millimeters and you can only have up to 1 decimal.
Effectively the same number, just a different unit of measure.
You can only see down to 0.1mm of accuracy in the dialogues - although you can type in more (you just can't see it).
Lingwisyer
Guru
Working Units will not change how your dimensions are shown, only how you measure and place things.
Options => Project Preferences => Dimensions
