Llian
Deleting a dimension...
Is there a way where I can delete a specific dimension say 800 without affecting the rest ?
I can delete it if I dimensioned each section separately..but this is time consuming.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
3 Replies 3
Erwin Edel
If you click 'on' the line below the 800 (the middle to be precise), you can select only that section of the line and delete it.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Llian
OMG……thank you..small little tip like this helps with time.
You can also select just a node and delete that also.
Delete the node at the end and that last dimension will disappear.
Delete a node inside of the dimension and the two adjoining dimensions will merge into one.
Also look at all of the options in the pet palette when you click on a dimension.
Where you click will bring up different options.
The places you can click on a dimension are the nodes, the centre of the line between two nodes, anywhere else in the line or the text.
Experiment a little (and read the manual) - you may be surprised at what you are missing.
