Dimension nodes disappearing randomly
Andrew T
I've been having issues with dimensions disappearing randomly from projects for quite some time. Unsure if it's an issue with the complex profile or a bug. It's been notably happening when jobs have been saved and re-opened but not to all walls/nodes. I'd usually end up redoing them, republishing, and noticing  down the line they've disappeared again. Any ideas on what could possibly be causing this, or suggestions on what I can try to fix this?
I have noticed that for the nodes that aren't missing, are the ones that aren't the reference line
Using Archicad 25 Build 6000
Thanks
10 REPLIES 10
We just started having issues in 3 different V27 files with dimensions disappearing. It's not a reno filter issue and it's not a structure display issue as far as I can tell. Always the same walls/objects, and if we add the dimensions back in, they'll eventually disappear, usually after switching to another view and then back. I've tried deleting the dimension string and adding a new one, but the same thing happens. As a core function of any CAD/BIM software, dimensioning needs to work 100% of the time, but this is extremely frustrating and completely unacceptable.
Graphisoft Certified BIM Manager
AC27 USA - build 6000 - HP ZBook 15 G6 - Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz, 16GB RAM - Windows 10 Pro
