Dimensions rounding?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2011-03-01
10:23 AM
ā2023-05-23
12:00 AM
Gordana Radonic
Is there any possibility (or maybe plug-in?) to set accuracy of dimensions (rounding)?
For example: original is 1881mm and I want 1880mm.
PLEH!! (to be visible in Revit's rear-view mirror)
- Labels:
Dimension Tools
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-02-17 09:07 AM
kliment wrote:................. so do I.
//....... so I prefer it the way it is now.
AC4.55 - AC14 INT (4204) | ļ£æ | OBJECTiVE |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-02-17 09:13 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-02-17 09:47 AM
kliment wrote:I agree.
Construction may not be a millimeter perfect, but modelling and drawings are.
If I want to round something to 5mm then I model it to the nearest 5mm.
5mm is not a standard unit of measurement but 10mm is (1 centimeter)
It is possible to set your working units to centimeters (with zero decimal accuracy) and still have your dimensions set to millimeters.
This way if you model accurately then all dims will be in 10mm increments.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-02-17 10:26 AM
When doing renovation work, which was probably built during imperial days,
and you measure as constructed you are faced with odd dimensions all the time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-03-27 01:58 PM
When drafting manually, drafters used rounded dimensions and an overall dimension - but deliberately left one dimension string blank. Its value was determined by subtracting the sum of the strings from the overall dimension. If you want to round in Archicad, you could do the same. Otherwise one would have to leave it up to the computer to decide where the difference is made up and this could be problematic.
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-03-27 10:24 PM
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-06-09 02:44 PM
so you will have 180cm displayed on your dimension lines
even if your model is 1801mm or 180.1 cm!
- Ā« Previous
- 1
- 2
- Next Ā»
- Ā« Previous
- 1
- 2
- Next Ā»
