pcrossington
Display elevation tags in elevation
I can't figure out how to display window tags on exterior elevation. I've always just shown them in plan, but I have a need for them to be on the elevations as well.
Thanks in advance.
Phil
Operating system used: Mac Apple Silicon sequoia 15.6.1 (24G90)
2 Solutions
JeffH
You can use an associative label, and then select the Door Window label that is loaded into your version of Archicad you are running.
AC24 / AC26 / AC27
Win10
Go to post
Ricardo Lopez
Hi @pcrossington
You can use the Property Label Type or Opening Label and change the frame shape, text, etc. to match whatever you need and save it as a favorite.
If you want to label all the windows at once in the elevation view:
  1. Select the Window tool.
  2. Ctrl (Command)+A to select them all.
  3. Menu Document> Annotation> Label Selected Elements.
Ricardo López, M. Arch.
Go to post
3 Replies 3
JeffH
AC24 / AC26 / AC27
Win10
Ricardo Lopez
Hi @pcrossington
pcrossington
Awesome - thanks so much!
