2003-12-18 08:31 PM - last edited on 2023-05-23 12:03 AM by Gordana Radonic
2003-12-18 09:15 PM
2003-12-19 05:46 AM
TomWaltz wrote:One for the wishlist ...
At the same time, is it possible to show section markers in the elevation view (so that building section markers are visible in elevation views)?
2003-12-19 05:51 PM
David wrote:labels do work w/ windows in plan & elevation. open up label tool select window tool, choose label: i have been told to use (ac8.0) wndw dr marker 2, set settings shape, size... set display options to not show dr/wndw dimn tick, select window in elev click on label , do the same in plan.
Currently, No (Both questions). These need to be on the Wish List, if they are not already.
Although... In AC8.1 they added the ability to "Label" elements in the Section/Elevation window. You could try using "Labels" rather than "Markers" as a work-around. We used to use "Labels" for Door/Window indicators before they introduced the customizable "Markers" in AC8.*.
2007-04-25 04:47 PM
